I have ported wifi driver for Android Kitkat on IMX6 sabresd and I have compiled the wpa_supplicant for 'bsd' , while trying to scan I am getting the unknown symbols in scan results in GUI.
Please, anyone help me to fix this,
1159 print_msg: ssid in driver is Test_5G
1160 print_msg: ssid in driver is WlanHCK-9695_5
1161 print_msg: ssid in driver is hmactest
1162 print_msg: ssid in driver is SAM9G65_5Ghz
1163 print_msg: ssid in driver is
1164 print_msg: ssid in driver is aDELL_5G
1165 print_msg: ssid in driver is UMAC_140
1166 print_msg: ssid in driver is Atech5G
1167 print_msg: ssid in driver is Loki
1168 print_msg: ssid in driver is AP10_5G
1169 print_msg: ssid in driver is LAB_AP_Network_5
1170 print_msg: ssid in driver is manpower
1171 print_msg: ssid in driver is ASUS_11AC
D/wpa_supplicant( 612): CTRL_IFACE monitor send - hexdump(len=39): 2f 64 61 74 61 2f 6d 69 73 63 2f 77 69 66 69 2f 73 6f 63 6b 65 74 73 2f 77 70 61 5f 63 74 72 6c ...
1681 E/WifiHW ( 448): Received the following from the supplicant: <3>CTRL-EVENT-BSS-ADDED 0 ec:1a:59:b2:6f:1e
1682 D/WifiMonitor( 448): RPS Received Event**********IFNAME=wlan0<3>CTRL-EVENT-BSS-ADDED 0 ec:1a:59:b2:6f:1e
1683 D/WifiMonitor( 448): Event [IFNAME=wlan0<3>CTRL-EVENT-BSS-ADDED 0 ec:1a:59:b2:6f:1e]
1684 D/WifiMonitor( 448): RPS IFNAME Found35 Space was mentioned
1685 D/WifiMonitor( 448): RPS Received Event**********wlan0
1686 D/WifiMonitor( 448): RPS Received Event123**********wlan0
1687 D/WifiMonitor( 448): RPS Received Event end of if **********CTRL-EVENT-BSS-ADDED 0 ec:1a:59:b2:6f:1e
1688 D/WifiMonitor( 448): Inside m.monitoring line RPS
1689 D/WifiMonitor( 448): RPS Before dispatch event
1690 D/WifiMonitor( 448): RPS Dispatch event **********
1691 D/WifiMonitor( 448): RPS eventName is BSS-ADDED 0 ec:1a:59:b2:6f:1e
1692 D/WifiMonitor( 448): RPS Name end is 9
1693 D/WifiMonitor( 448): RPS event
1694 D/WifiMonitor( 448): 10
1695 D/WifiMonitor( 448): RPS not event state change -1
1696 D/WifiMonitor( 448): RPS event data is: CTRL-EVENT-BSS-ADDED 0 ec:1a:59:b2:6f:1e
1697 D/WifiMonitor( 448): RPS event is: 10
1698 D/WifiMonitor( 448): RPS Handle event
1699 D/WifiMonitor( 448): 10
1700 E/wpa_supplicant( 612): ssid_txt ^A sizeof(ssid_txt) 4
1701 E/wpa_supplicant( 612): printf_encode ssid len 4
1702 E/wpa_supplicant( 612): printf_encode: ssid char ^A
1703 E/wpa_supplicant( 612): printf_encode: ssid char
1704 E/wpa_supplicant( 612): printf_encode: ssid char
1705 E/wpa_supplicant( 612): printf_encode: ssid char
1706 E/wpa_supplicant( 612): printf_encode: ssid \x01\x00\x00\x00
1707 D/wpa_supplicant( 612): wlan0: BSS: Add new id 1 BSSID 68:86:a7:cb:59:dc SSID '\x01\x00\x00\x00'
1708 D/wpa_supplicant( 612): CTRL_IFACE monitor send - hexdump(len=39): 2f 64 61 74 61 2f 6d 69 73 63 2f 77 69 66 69 2f 73 6f 63 6b 65 74 73 2f 77 70 61 5f 63 74 72 6c ...
E/wpa_supplicant( 612): printf_encode: ssid \x00\x00\x00\x00\x00\x00\x00
D/wpa_supplicant( 612): wlan0: BSS: Add new id 6 BSSID 54:a0:50:5c:68:1c SSID '\x00\x00\x00\x00\x00\x00\x00'
D/wpa_supplicant( 612): wlan0: BSS: Add new id 9 BSSID c8:b3:73:36:a6:6b SSID '\x00\x00\x00\x00\x00\x00\x00'
E/wpa_supplicant( 612): printf_encode: ssid \x00\x00\x00\x00\x00\x00\x00\x00D
D/wpa_supplicant( 612): wlan0: BSS: Add new id 12 BSSID 1c:87:2c:e3:7e:ac SSID '\x00\x00\x00\x00\x00\x00\x00\x00D'
E/wpa_supplicant( 612): printf_encode: ssid \x00\x00\x00\x00\x00\x00\x00\x00\x8a\xf1,$
D/wpa_supplicant( 612): wlan0: BSS: Add new id 14 BSSID 54:a0:50:5c:68:18 SSID '\x00\x00\x00\x00\x00\x00\x00\x00\x8a\xf1,$'
D/wpa_supplicant( 612): wlan0: BSS: Add new id 16 BSSID 68:86:a7:cb:22:2c SSID '\x01\x00\x00\x00'
D/wpa_supplicant( 612): wlan0: BSS: Add new id 37 BSSID 68:86:a7:cb:22:23 SSID '\x01\x00\x00\x00'
Susan
