Hi all,
We use rtl8723bs bt on sabresd_6dq. But mic don't work. please see follow log(pair and use bt to call):
Who knows what's the problem?
pair bt:
W/AudioTrack( 434): AUDIO_OUTPUT_FLAG_FAST denied by client
W/AudioPolicyManager( 170): releaseOutput() releasing unknown output 14
I/audio_hw_primary( 170): start_output_stream... 1981511424, device 2
W/audio_hw_primary( 170): card 0, port 0 device 0x2
W/audio_hw_primary( 170): rate 44100, channel 2 period_size 0xc0
D/BluetoothHeadset( 2435): connect(1C:52:16:0B:47:44)
D/HeadsetStateMachine( 2498): currentState is Disconnected
D/HeadsetService( 2498): connectionState = 0
D/CachedBluetoothDevice( 2435): Command sent successfully:CONNECT Address:1C:52:16:0B:47:44 Profile:HEADSET
D/BluetoothA2dp( 2435): connect(1C:52:16:0B:47:44)
D/CachedBluetoothDevice( 2435): Command sent successfully:CONNECT Address:1C:52:16:0B:47:44 Profile:A2DP
D/HeadsetStateMachine( 2498): Disconnected process message: 1, size: 0
D/HeadsetStateMachine( 2498): Connection state 1C:52:16:0B:47:44: 0->1
D/BluetoothAdapterService( 2498): getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@2a94968e
I/BluetoothHeadsetServiceJni( 2498): connectHfpNative: sBluetoothHfpInterface: 0x65482abc
D/BluetoothAdapterProperties( 2498): CONNECTION_STATE_CHANGE: 1C:52:16:0B:47:44: 0 -> 1
D/HeadsetStateMachine( 2498): Exit Disconnected: 1
D/HeadsetStateMachine( 2498): Enter Pending: 1
D/CachedBluetoothDevice( 2435): onProfileStateChanged: profile HEADSET newProfileState 1
D/A2dpStateMachine( 2498): Disconnected process message: 1
I/art ( 434): Explicit concurrent mark sweep GC freed 12823(597KB) AllocSpace objects, 2(32KB) LOS objects, 33% free, 11MB/17MB, paused 2.027ms total 151.189ms
I/BluetoothA2dpServiceJni( 2498): connectA2dpNative: sBluetoothA2dpInterface: 0x654829b4
D/A2dpStateMachine( 2498): Exit Disconnected: 1
D/A2dpStateMachine( 2498): Enter Pending: 1
D/A2dpStateMachine( 2498): Connection state 1C:52:16:0B:47:44: 0->1
D/CachedBluetoothDevice( 2435): onProfileStateChanged: profile A2DP newProfileState 1
E/bt-l2cap( 2498): l2cu_adjust_out_mps bad packet size: 0 will use MPS: 0
W/bt-btif ( 2498): info:x0
D/ ( 2498): remote version info [1c:52:16:0b:47:44]: 6, a, 21c8
W/bt-sdp ( 2498): process_service_search_attr_rsp
W/bt-btif ( 2498): new conn_srvc id:5, app_id:0
I/BluetoothHeadsetServiceJni( 2498): connection_state_callback
D/HeadsetStateMachine( 2498): Pending process message: 101, size: 0
D/HeadsetStateMachine( 2498): event type: 1
D/HeadsetStateMachine( 2498): getDeviceForMessage: returning mTargetDevice for what=201
D/HeadsetStateMachine( 2498): remove connect timeout for device = 1C:52:16:0B:47:44
D/HeadsetStateMachine( 2498): processConnectionEvent state = 2, device = 1C:52:16:0B:47:44
D/HeadsetStateMachine( 2498): device 1C:52:16:0B:47:44 is added in Pending state
D/HeadsetStateMachine( 2498): Connection state 1C:52:16:0B:47:44: 1->2
E/bt-rfcomm( 2498): PORT_DataInd, p_port:0x6556bb84, p_data_co_callback is null
D/BluetoothAdapterProperties( 2498): CONNECTION_STATE_CHANGE: 1C:52:16:0B:47:44: 1 -> 2
D/CachedBluetoothDevice( 2435): onProfileStateChanged: profile HEADSET newProfileState 2
D/AudioPolicyManager( 170): setDeviceConnectionState() could not find HW module for device 00000020
W/AudioPolicyManager( 170): setDeviceConnectionState(): could not find HW module for device 80000008
W/audio_hw_primary( 170): set parameters bt_headset_name=QY7;bt_headset_nrec=on
E/audio_a2dp_hw( 170): adev_set_parameters: ERROR: set param called even when stream out is null
D/HeadsetStateMachine( 2498): configAudioParameters for device:1C:52:16:0B:47:44 are: nrec = 1
D/HeadsetStateMachine( 2498): Enter Connected: 101, size: 1
D/HeadsetStateMachine( 2498): Connected process message: 101, size: 1
D/HeadsetStateMachine( 2498): event type: 12event device : 1C:52:16:0B:47:44
I/BluetoothHeadsetServiceJni( 2498): cindResponseNative: sBluetoothHfpInterface: 0x65482abc
I/BluetoothA2dpSinkServiceJni( 2498): bta2dp_connection_state_callback
E/bt-btif ( 2498): reset flags
D/A2dpSinkStateMachine( 2498): Disconnected process message: 101
D/HeadsetStateMachine( 2498): event type: 1event device : 1C:52:16:0B:47:44
D/HeadsetStateMachine( 2498): processConnectionEvent state = 3, device = 1C:52:16:0B:47:44
I/A2dpSinkStateMachine( 2498): Incoming A2DP accepted
I/Telecom ( 752): BluetoothPhoneService: queryPhoneState
I/Telecom ( 752): BluetoothPhoneService: updateHeadsetWithCallState numActive 0, numHeld 0, callState 6, ringing number [da39a3ee5e6b4b0d3255bfef95601890afd80709], ringing type 128
D/A2dpSinkStateMachine( 2498): Exit Disconnected: 101
D/A2dpSinkStateMachine( 2498): Enter Pending: 101
D/A2dpSinkStateMachine( 2498): Connection state 1C:52:16:0B:47:44: 0->1
D/HeadsetStateMachine( 2498): Connected process message: 9, size: 1
D/HeadsetStateMachine( 2498): mNumActive: 0 mNumHeld: 0 mCallState: 6
D/HeadsetStateMachine( 2498): mNumber: mType: 128
D/HeadsetStateMachine( 2498): terminateScoUsingVirtualVoiceCall: Received
E/HeadsetStateMachine( 2498): terminateScoUsingVirtualVoiceCall:No present call to terminate
D/HeadsetStateMachine( 2498): event type: 9event device : 1C:52:16:0B:47:44
D/HeadsetStateMachine( 2498): NREC value for device :1C:52:16:0B:47:44 is: 0
D/HeadsetStateMachine( 2498): event type: 6event device : 1C:52:16:0B:47:44
D/HeadsetStateMachine( 2498): Connected process message: 7, size: 1
E/bt-btif ( 2498): bta_av_rc_create ACP handle exist for shdl:0
W/bt-btif ( 2498): btif_av_state_opening_handler : unhandled event:BTA_AV_PENDING_EVT
D/HeadsetStateMachine( 2498): event type: 15event device : 1C:52:16:0B:47:44
D/HeadsetStateMachine( 2498): processUnknownAt - atString = +XAPL=0000-0000-0100,7
D/HeadsetStateMachine( 2498): processVendorSpecificAt - atString = +XAPL=0000-0000-0100,7
E/HeadsetStateMachine( 2498): processVendorSpecificAt: unsupported command: +XAPL=0000-0000-0100,7
D/HeadsetStateMachine( 2498): processUnknownAt - atString = +IPHONEACCEV=2,1,8,2,0
D/HeadsetStateMachine( 2498): processVendorSpecificAt - atString = +IPHONEACCEV=2,1,8,2,0
E/HeadsetStateMachine( 2498): processVendorSpecificAt: unsupported command: +IPHONEACCEV=2,1,8,2,0
D/HeadsetStateMachine( 2498): processUnknownAt - atString = +XEVENT=foo,8
D/HeadsetStateMachine( 2498): processVendorSpecificAt - atString = +XEVENT=FOO,8
D/HeadsetStateMachine( 2498): broadcastVendorSpecificEventIntent(+XEVENT)
D/HeadsetStateMachine( 2498): event type: 14event device : 1C:52:16:0B:47:44
I/Telecom ( 752): BluetoothPhoneService: listcurrentCalls
D/HeadsetStateMachine( 2498): Starting CLCC response timeout for device: 1C:52:16:0B:47:44
D/HeadsetStateMachine( 2498): Connected process message: 12, size: 1
D/HeadsetStateMachine( 2498): getDeviceForMessage: returning 1C:52:16:0B:47:44
D/HeadsetStateMachine( 2498): processUnknownAt - atString = +CSRSF=0,0,0,1,0,0,0
D/HeadsetStateMachine( 2498): processVendorSpecificAt - atString = +CSRSF=0,0,0,1,0,0,0
E/HeadsetStateMachine( 2498): processVendorSpecificAt: unsupported command: +CSRSF=0,0,0,1,0,0,0
W/audio_hw_primary( 170): do_out_standby... 1981511424
W/bt-btif ( 2498): bta_dm_rm_cbacinput: AVRCP as /devices/virtual/input/input3
k:0, status:0
W/bt-btif ( 2498): new conn_srvc id:18, app_id:0
I/BluetoothA2dpServiceJni( 2498): bta2dp_connection_state_callback
E/bt-btif ( 2498): use_rc:1
D/A2dpStateMachine( 2498): Pending process message: 101
E/bt-btif ( 2498): bta_av_rc_opened rcb[0] shdl:1 lidx:3/0
W/bt-btif ( 2498): blacklist absolute volume for 1c:52:16, name = QY7
I/BluetoothAvrcpServiceJni( 2498): btavrcp_remote_features_callback
D/A2dpStateMachine( 2498): Enter Connected: 101
D/A2dpStateMachine( 2498): Connection state 1C:52:16:0B:47:44: 1->2
D/A2dpStateMachine( 2498): A2DP Playing state : device: 1C:52:16:0B:47:44 State:10->11
D/CachedBluetoothDevice( 2435): onProfileStateChanged: profile A2DP newProfileState 2
I/audio_a2dp_hw( 170): adev_open_output_stream: opening output
I/audio_a2dp_hw( 170): skt_connect: connect to /data/misc/bluedroid/.a2dp_ctrl (sz 10240)
I/audio_a2dp_hw( 170): skt_connect: connected to stack fd = 17
I/AudioFlinger( 170): HAL output buffer size 2560 frames, normal sink buffer size 2560 frames
I/AudioFlinger( 170): AudioFlinger's thread 0x74022000 ready to run
I/audio_a2dp_hw( 170): out_set_parameters: state 3
I/str_params( 170): key: 'a2dp_sink_address' value: '1C:52:16:0B:47:44'
D/EventHub( 434): No input device configuration file found for device 'AVRCP'.
I/AudioFlinger( 170): AudioFlinger's thread 0x74063000 ready to run
W/audio_hw_primary( 170): set parameters A2dpSuspended=false
I/audio_a2dp_hw( 170): adev_set_parameters: state 3
I/str_params( 170): key: 'A2dpSuspended' value: 'false'
W/EventHub( 434): Unable to disable kernel key repeat for /dev/input/event2: Function not implemented
I/EventHub( 434): New device: id=4, fd=186, path='/dev/input/event2', name='AVRCP', classes=0x80000001, configuration='', keyLayout='/system/usr/keylayout/AVRCP.kl', keyCharacterMap='/system/usr/keychars/Generic.kcm', builtinKeyboard=false, wakeMechanism=EPOLLWAKEUP, usingClockIoctl=true
I/InputReader( 434): Device added: id=4, name='AVRCP', sources=0x00000101
I/BluetoothAvrcpServiceJni( 2498): btavrcp_register_notification_callback
I/BluetoothAvrcpServiceJni( 2498): registerNotificationRspPlayStatusNative: sBluetoothAvrcpInterface: 0x65482c24
I/BluetoothAvrcpServiceJni( 2498): registerNotificationRspPlayPosNative: sBluetoothAvrcpInterface: 0x65482c24
D/Index ( 2435): Indexing locale 'en_AU' took 81 millis
D/btif_config_util( 2498): btif_config_save_file(L188): in file name:/data/misc/bluedroid/bt_config.new
W/bt-btif ( 2498): dm_pm_timer expires
W/bt-btif ( 2498): dm_pm_timer expires 0
W/bt-btif ( 2498): proc dm_pm_timer expires
use bt to call:
W/audio_hw_primary( 170): out_set_parameters routing=2, ret 0, out 1981511424
W/audio_hw_primary( 170): do_in_standby..
W/audio_hw_primary( 170): ret -32, pcm write 768 error wait error: hw 0x8ff40 app 0x90540 avail 0x0
W/audio_hw_primary( 170): : Unknown error -32
W/AudioRecord( 1908): AUDIO_INPUT_FLAG_FAST denied by client
W/audio_hw_primary( 170): In channels 1, rate 48000, devices 0x80000004
W/audio_hw_primary( 170): get_input_buffer_size size = 1120, channel_count = 1
I/AudioFlinger( 170): AudioFlinger's thread 0x740b6000 ready to run
W/audio_hw_primary( 170): in_set_parameters input_source=1;routing=-2147483644, ret 11
V/skype_jni( 1908): jni_CallDevice::SetRoute(0_2)
V/skype_jni( 1908): jni_CallDevice::UseRoute(0_2) done 0
W/audio_hw_primary( 170): start_input_stream....
W/audio_hw_primary( 170): card 0, port 0 device 0x4
W/audio_hw_primary( 170): rate 44100, channel 2 format 0, period_size 0x400
V/skype_jni( 1908): jni_CallDevice::SetRoute(1_2)
V/skype_jni( 1908): jni_CallDevice::UseRoute(1_2) done 0
W/AudioTrack( 434): dead IAudioTrack, PCM, creating a new one from processAudioBuffer()
Solved! Go to Solution.
Hi Shannon
If you want to use HFP and HSP, you need to feed voice to audio codec
like sabresd WM8962. Then through WM8962 rtl8723bs can get this pcm stream.
On sabresd board there is no such path for audio codec (need more pcm rx/tx pin),
so only way was to connect AR6233 using UART to processor. For these reasons
there is no way to support HSP and HSP on sabresd. This is meaning of
"Handset & Handfree(not support for hardware restrict)" mentioned on
How to enable BT on board imx6q_sabresd RevC. .
Hi all,
We use bt record to rec audio. The error log:
I/audio_a2dp_hw( 169): start_audio_datapath: state 5
E/audio_a2dp_hw( 169): start_audio_datapath: audiopath start failed
W/AudioTrack( 435): AUDIO_OUTPUT_FLAG_FAST denied by client
I/AudioService( 1398): ===>Call startRecorder
D/AudioService( 1398): ---> stopRecord mode = 0 mMimeType= 0
I/audio_a2dp_hw( 169): out_set_parameters: state 5
I/str_params( 169): key: 'routing' value: '128'
I/str_params( 169): key: 'a2dp_sink_address' value: '1C:48:F9:18:E2:EC'
D/AudioService( 1398): ---> startRecorder mode = 2 mMimeType= 0
W/audio_hw_primary( 169): In channels 1, rate 8000, devices 0x80000004
W/audio_hw_primary( 169): get_input_buffer_size size = 192, channel_count = 1
I/AudioFlinger( 169): AudioFlinger's thread 0x74301000 ready to run
W/bt-btif ( 2033): bta_dm_rm_cback:1, status:7
I/MediaCodecSource( 169): MediaCodecSource (audio) starting
W/audio_hw_primary( 169): in_set_parameters input_source=1;routing=-2147483644, ret 11
I/MediaCodecSource( 169): MediaCodecSource (audio) started
I/AudioService( 1398): ---> startRecorder mCurMode = 2
D/AudioService( 1398): ===> startRecorder isBluetoothA2dpOn = true isBluetoothScoOn = false
W/audio_hw_primary( 169): start_input_stream....
W/audio_hw_primary( 169): card 0, port 0 device 0x4
W/audio_hw_primary( 169): rate 44100, channel 2 format 0, period_size 0x400
E/bt-btif ( 2033): bta_av_link_role_ok hndl:x41 role:0, conn_audio:x1, bits:1, features:x824b
W/bt-btif ( 2033): bta_dm_rm_cback:1, status:0
I/BluetoothA2dpServiceJni( 2033): bta2dp_audio_state_callback
I/audio_a2dp_hw( 169): skt_connect: connect to /data/misc/bluedroid/.a2dp_data (sz 10240)
I/audio_a2dp_hw( 169): skt_connect: connected to stack fd = 25
D/A2dpStateMachine( 2033): Connected process message: 101
D/A2dpStateMachine( 2033): A2DP Playing state : device: 1C:48:F9:18:E2:EC State:11->10
W/bt-btif ( 2033): overflow 0, enter 0, exit 0
W/bt-btif ( 2033): pcm bytes per tick 3528
D/BluetoothHeadset( 435): startScoUsingVirtualVoiceCall()
D/HeadsetStateMachine( 2033): currentState = com.android.bluetooth.hfp.HeadsetStateMachine$Connected@27d8d2b
D/HeadsetStateMachine( 2033): Connected process message: binder: 435:435 transaction failed 29189, size 172-0
14, size: 1
D/HeadsetStateMachine( 2033): initiateScoUsingVirtualVoiceCall: Received
D/HeadsetStateMachine( 2033): mNumActive: 0 mNumHeld: 0 mCallState: 2
D/HeadsetStateMachine( 2033): mNumber: mType: 0
D/HeadsetStateMachine( 2033): mNumActive: 0 mNumHeld: 0 mCallState: 3
D/HeadsetStateMachine( 2033): mNumActive: 1 mNumHeld: 0 mCallState: 6
D/HeadsetStateMachine( 2033): initiateScoUsingVirtualVoiceCall: Done
D/bt_vendor( 2033): op for 8
D/AudioService( 1398): ===> audio sco state = 0
D/AudioService( 1398): ===> audio sco state = 2
I/audio_a2dp_hw( 169): suspend_audio_datapath: state 1
E/bt-btif ( 2033): bta_av_str_stopped:audio_open_cnt=1, p_data 6ded4ccc
W/bt-btif ( 2033): bta_dm_rm_cback:1, status:6
I/audio_a2dp_hw( 169): skt_disconnect: fd 25
D/A2dpStateMachine( 2033): A2DP Playing state : device: 1C:48:F9:18:E2:EC State:10->11
W/bt-btif ( 2033): bta_av_suspend_cfm: already suspended, ignore, err_code 49
D/HeadsetStateMachine( 2033): Connected process message: 101, size: 1
D/HeadsetStateMachine( 2033): event type: 2event device : 1C:48:F9:18:E2:EC
D/HeadsetStateMachine( 2033): Set NREC: 0 for device:1C:48:F9:18:E2:EC
W/audio_hw_primary( 169): set parameters bt_headset_nrec=off
I/audio_a2dp_hw( 169): adev_set_parameters: state 5
I/str_params( 169): key: 'bt_headset_nrec' value: 'off'
W/bt-btif ( 2033): bta_dm_rm_cback:1, status:1
I/BluetoothA2dpServiceJni( 2033): bta2dp_connection_state_callback
W/audio_hw_primary( 169): set parameters bt_headset_name=JABRA EASYCALL
I/str_params( 169): key: 'bt_headset_name' value: 'JABRA EASYCALL'
D/A2dpStateMachine( 2033): Enter Disconnected: 101
D/HeadsetStateMachine( 2033): Audio state 1C:48:F9:18:E2:EC: 11->12
D/HeadsetStateMachine( 2033): Enter AudioOn: 101, size: 1
D/AudioService( 1398): ===> audio sco state = 1
I/AudioService( 1398): AudioManager.SCO_AUDIO_STATE_CONNECTED
W/MediaSessionRecord( 435): Removed dead callback in pushPlaybackStateUpdate.
W/MediaSessionRecord( 435): android.os.DeadObjectException
W/MediaSessionRecord( 435): at android.os.BinderProxy.transactNative(Native Method)
W/MediaSessionRecord( 435): at android.os.BinderProxy.transact(Binder.java:496)
W/MediaSessionRecord( 435): at android.media.session.ISessionControllerCallback$Stub$Proxy.onPlaybackStateChanged(ISessionControllerCallback.java:209)
W/MediaSessionRecord( 435): at com.android.server.media.MediaSessionRecord.pushPlaybackStateUpdate(MediaSessionRecord.java:478)
W/MediaSessionRecord( 435): at com.android.server.media.MediaSessionRecord.access$3300(MediaSessionRecord.java:66)
W/MediaSessionRecord( 435): at com.android.server.media.MediaSessionRecord$MessageHandler.handleMessage(MediaSessionRecord.java:1211)
W/MediaSessionRecord( 435): at android.os.Handler.dispatchMessage(Handler.java:102)
W/MediaSessionRecord( 435): at android.os.Looper.loop(Looper.java:135)
W/MediaSessionRecord( 435): at com.android.server.SystemServer.run(SystemServer.java:269)
W/MediaSessionRecord( 435): at com.android.server.SystemServer.main(SystemServer.java:170)
W/MediaSessionRecord( 435): at java.lang.reflect.Method.invoke(Native Method)
W/MediaSessionRecord( 435): at java.lang.reflect.Method.invoke(Method.java:372)
W/MediaSessionRecord( 435): at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:899)
W/MediaSessionRecord( 435): at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:694)
W/AudioTrack( 435): dead IAudioTrack, PCM, creating a new one from processAudioBuffer()
W/audio_hw_primary( 169): set parameters 1C:48:F9:18:E2:EC=;disconnect=128
D/A2dpStateMachine( 2033): Connection state 1C:48:F9:18:E2:EC: 2->0
D/BluetoothAdapterService( 2033): getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@3eba5f3b
D/AudioService( 1398): ===>BluetoothA2dp state = 0
D/CachedBluetoothDevice( 1335): onProfileStateChanged: profile A2DP newProfileState 0
D/BluetoothHeadset( 435): stopScoUsingVirtualVoiceCall()
D/HeadsetStateMachine( 2033): currentState = com.android.bluetooth.hfp.HeadsetStateMachine$AudioOn@2aba6588
D/HeadsetStateMachine( 2033): AudioOn process message: 15, size: 1
D/HeadsetStateMachine( 2033): terminateScoUsingVirtualVoiceCall: Received
D/HeadsetStateMachine( 2033): mNumActive: 0 mNumHeld: 0 mCallState: 6
D/HeadsetStateMachine( 2033): terminateScoUsingVirtualVoiceCall: Done
E/bt_h5 ( 2033): HCI Connection handle(0x3) not found
D/HeadsetStateMachine( 2033): AudioOn process message: 101, size: 1
E/HeadsetStateMachine( 2033): terminateScoUsingVirtualVoiceCall:No present call to terminate
D/HeadsetStateMachine( 2033): Audio state 1C:48:F9:18:E2:EC: 12->10
D/HeadsetStateMachine( 2033): Enter Connected: 101, size: 1
I/str_params( 169): key: '1C:48:F9:18:E2:EC' value: ''
I/str_params( 169): key: 'disconnect' value: '128'
I/str_params( 169): key: 'exiting' value: '1'
W/AudioSystem( 435): ioConfigChanged() closing unknown output! 467
I/str_params( 169): key: 'routing' value: '0'
E/bt-btif ( 2033): reset flags
W/bt-btif ( 2033): new conn_srvc id:18, app_id:0
W/bt-btif ( 2033): btif_av_state_idle_handler : unhandled event:BTA_AV_OPEN_EVT
W/bt-btif ( 2033): btif_av_state_idle_handler : unhandled event:BTA_AV_START_EVT
I/str_params( 169): key: 'closing' value: 'true'
I/audio_a2dp_hw( 169): out_set_parameters: state 2
W/AudioSystem( 435): ioConfigChanged() closing unknown output! 466
I/audio_a2dp_hw( 169): adev_close_output_stream: closing output (state 2)
I/audio_a2dp_hw( 169): stop_audio_datapath: state 2
I/audio_a2dp_hw( 169): skt_disconnect: fd -1
I/audio_a2dp_hw( 169): skt_disconnect: fd 26
W/bt-sdp ( 2033): process_service_search_attr_rsp
E/bt-btif ( 2033): handle_rc_connect Connect failed with error code: 2
Hi Shannon
seems this is because Handset & Handfree profiles are not supported
(due to MX6 SabreSD hardware restrict as described below)
https://community.freescale.com/docs/DOC-94235
Hi igorpadykov,
We use bt is rtl8723bs. It support HSP/HFP. And What do we need to modify can let HSP and HFP work normally?
Hi Shannon
