add 64GB eMMC in the imx8mq evk board
Search instead for
pingyuchen
I want to add 64GB eMMC in the imx8mq evk board, what do I modify for it?
Thanks!
Hi pingyi
please check sect.2.6. eMMC memory (U601) MX8M EVK Board Hardware User's Guide
https://www.nxp.com/docs/en/user-guide/IMX8MDQLQEVKHUG.pdf
and p.9 EVK schematic
Schematics (1)
Design Files for the i.MX 8M Evaluation Kit
https://www.nxp.com/support/developer-resources/run-time-software/i.mx-developer-resources/evaluatio...
pingyuchen
Hi igor,
How can I create the file partition-table.img for 64GB emmc?
pingyuchen
Hi igor,
Thanks for your response. I also want to know how to modify the software and others to support 64GB eMMC.
Thanks!
Hi pingyi
you can just replace emmc without software modifications.
pingyuchen
Hi igor,
Which partition-table file do I use for 64GB emmc? I had a board with 64GB emmc and flashed it by using the partition-table-28GB.img, it can be recognized 32GB.
Hi pingyi
please check suggestions on
How to partion eMMc on i.MX6DL properly?
One can create own partition table using sect.5.1.1 Storage partitions
attached Android User Guide.
