about imx6q hdmi driver on linux
已解决
跳至解决方案
1,853 次查看
andypeng
Hi all,
  I display the vedio with HDMI out to TV,At the beginning of the sounds and images are correct, but after about 8 minutes, the TV image without (black), voice and. To plug the HDMI cable, fault can not be restored, what is wrong?
标签 (2)
1 解答
1,648 次查看
weidong_sun
Hello,andypeng,
     It seems that system entered into sleep status. You can try to press power button to wake it up !
Weidong
在原帖中查看解决方案
2 回复数
1,649 次查看
weidong_sun
Hello,andypeng,
Weidong
1,648 次查看
andypeng
Weidong Sun 撰写:
Hello,andypeng,
Weidong
Hi Weidong,
   Thank you for your reply.I can wake it up when i press the SW4–Volume Up Button,not SW1–Optional Power Button on
SABRE Board imx6Q.
  I want to disable the function when i player vedio , could tell me How to modify the driver?
