Board:i.MX6Q EVK
Audio Codec Chip:wm8962
When I run Linux version on i.MX6Q,and I record file from MIC-Jack,no voice.And I check the EVK,found it no Mic Bias Voltage.How to Setup?
When I run Android version on i.MX6Q,have this Mic Bios Level
解決済! 解決策の投稿を見る。
wangshengjiu Sep 27, 2013 12:14 AM (in response to Dan Wang)
Hi Dan wang
For recording, user need to set the some parameters through amixer. please try below command.
amixer cset numid=10,iface=MIXER,name='Capture Switch' on
amixer sset 'Capture' 100
amixer sset 'INPGAR IN3R' on
amixer sset 'MIXINR IN3R' on
Hi Karina,
Could you show me how to connect an electret microphone to the MIC IN jack?
I tried shorting the MIC BIAS and MIC IN connections but there is no voice recorded, thanks!
Hi Dan wang
