Zephyr - mimxrt1060_evkb - watchdog and SMP problem
Search instead for
gronoarona
Hello
I have quite big problem.
I'm using MCUBoot and SMP to download image and it works (when no task are registered to watchdog_task), i'm able to flash new image and run it.
But when i register any task to watchdog_task, i'm not able to upload new image via SMP.
More specifically: whenever I try to upload a new program, the processor freezes and this causes watchdog CPU reset, is there any workaround on this?
I was wrote about this problem to zephyr github but no one answear.
Many thanks for any help.
nxf77486
Hello @gronoarona ,
Thank you for contacting NXP support.
Unfortunately we do not have support for Zephyr through this channel, so we do not have available a workaround for this.
I will recommend in order to received support about Zephyr consult the following Zephyr community. Please let me know if I can help you on anything else I will be happy to assist you.
Zephyr Community Support
