Zephyr - mimxrt1060_evkb - trng takes 24 seconds.
Search instead for
gronoarona
Hello
I'm using zephyr witch config  CONFIG_HARDWARE_DEVICE_CS_GENERATOR
Which should allow me to use RTNG to DTLS purposes.
Unfortunately, when i try to establish connection on UDP DTLS Client socket it takes 24 second.
( without CONFIG_HARDWARE_DEVICE_CS_GENERATOR it takes a few ms). I assume this is the problem on RTNG.
Is there any possible to speedup TRNG?
Zephyr use the same api and configuration like here:
https://mcuxpresso.nxp.com/api_doc/dev/210/group__trng.html#a2f0603394bb7074023fe0f42b36cd235
danielchen
As described in our Zephyr NXP Support Landing Page, we prefer to support Zephyr users in GitHub.
I would suggest you post your questions on Zephyr Project Github.
