Yocto4.0 meta-imxb/meta-timesysb SSL certificate problem
charleshuang
Senior Contributor II
Hi NXP team,
As title.
When I build execute "repo sync", I got below message about ssl problem.
Please help to check, thanks!
Fetching: 28% (4/14) meta-imxb' % Total % Received % Xferd Average Speed Time Time Time Current\n Dload Upload Total Spent Left Speed\n\r 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0\r 0 0 0 0 0 0 0 0 --:--:-- 0:00:01 --:--:-- 0\r 0 0 0 0 0 0 0 0 --:--:-- 0:00:01 --:--:-- 0\ncurl: (60) SSL certificate problem: self signed certificate in certificate chain\nMore details here: https://curl.haxx.se/docs/sslcerts.html\n\ncurl failed to verify the legitimacy of the server and therefore could not\nestablish a secure connection to it. To learn more about this situation and\nhow to fix it, please visit the web page mentioned above.\n'
Fetching: 57% (8/14) meta-timesysb' % Total % Received % Xferd Average Speed Time Time Time Current\n Dload Upload Total Spent Left Speed\n\r 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0\r 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0\ncurl: (60) SSL certificate problem: self signed certificate in certificate chain\nMore details here: https://curl.haxx.se/docs/sslcerts.html\n\ncurl failed to verify the legitimacy of the server and therefore could not\nestablish a secure connection to it. To learn more about this situation and\nhow to fix it, please visit the web page mentioned above.\n'
charleshuang
Hi Joanxie,
Sorry to bother you.
It just look like network problem.
I will close this post later.
Thanks !
joanxie
pls share your detailed build steps before repo sync
charleshuang
Hi Joanxie,
Thanks !
