I had succeeded build "imx-image-multimedia" and "imx-image-full" images before.
Next, I delete the "tmp/deploy" folder.
Next, I can't build "imx-image-multimedia" successfully.
The build error is the "tmp/deploy/deb/cortexa53-crypto/iputils-ping_s20200821-r0_arm64.deb" doesn't exist.
I don't know how to fix or rebuild it.
Hi aresshsiao,
The folder that you erase usually contains the previous data used by the build, and the system detects that you already did a built so you need to do a new deployment in a new folder.
Israel.
