Yocto project build not successfull
1,038 次查看
omsakthiramu
Hi ,
I  am trying to build  Yocto project for IMX8QXPMEK varaiant. I am building image for fsl-image-validation-imx.
I am getting error in the middle of the build process. Can any one help me to resolve the error.
I have attached the error log for the reference.
In the attached error log, I Could see the url is not reachable.
http://downloads.yoctoproject.org/mirror/sources/git2_git.freescale.com.proprietary.imx-firmware.git... , this path not valid. Do we need to change. If yes what we have change
标签 (1)
2 回复数
911 次查看
Bio_TICFSL
Hi Omsakthi,
You have problem with your network settings, or the bad nxp git, if that the case you should be able to do it now.
911 次查看
omsakthiramu
The issue got resolved. There are two different URL's to download the firmware. I have corrected the URL in .bb file. then build succeeded.
Thanks.
