Yocto openssh
Yocto openssh
11,889 次查看
LPs
Hi all,
  I'm working with Yocto fsl-relese-bsp.
I'm baking fsl-image-qt5, and I added the ssh-server-openssh EXTRA_IMAGE_FEATURES to the recipe.
The bitbake worked well, but after the startup the root user ask me for a password.
Before adding ssh-server-openssh the root password was empty.
What is the standard password for this package?
标签 (3)
4,742 次查看
gusarambula
Hello LPs,
You may find useful to see the EXTRA_IMAGE_FEATURES section on the Yocto reference manual (link below). Especially the debug-tweaks feature which sets the ssh root access to a blank password.
http://www.yoctoproject.org/docs/1.7/ref-manual/ref-manual.html#var-EXTRA_IMAGE_FEATURES
If you’re looking for a more permanent solution you should patch the source code to add the desired username and password.
