Yocto gstreamer-1.0-plugin-bad rtmpsink rtmpsrc
1,566 次查看
zhaoyun_zzz
I want use gstreamer elements like rtmpsink and rtmpsrc, but currently I use yocto to bitbake fsl-image-qt5, in the "/build-fb/tmp/deploy/images/imx6qsabresd" directory, the roofs seems don't have the libgstrtmp.so
So, how should I config the yocto to build fsl-image-qt5,with gstreamer that have element rtmpsink and rtmpsrc?
Any one can help me ? Thanks!
标签 (3)
1 回复
1,340 次查看
Bio_TICFSL
You need alsa for ligstrtmp,
PACKAGECONFIG_append_pn-qtmultimedia = " gstreamer alsa"
