Yocto build with Qt support for MiMX8QX6AVLFZAC
1,461 次查看
kishorem
We are trying to build yocto image with Qt support for the processor MiMX8QX6AVLFZAC and using following configuration.
MACHINE=imx8qxpmek DISTRO=fsl-imx-xwayland source ./imx-setup-release.sh -b bld-xwayland
the above machine name and distro are correct ?
1,443 次查看
Bio_TICFSL
It should be:
$ DISTRO=fsl-imx-wayland MACHINE=imx8mqx source fsl-setup-release.sh -b build-wayland
$ bitbake fsl-image-qt5-validation-imx
1,417 次查看
kishorem
We are getting machine invalid error and we have also attached the screenshot.
Following is the list of potential problems / advisories:
MACHINE=imx8mqx is invalid. Please set a valid MACHINE in your local.conf, environment or other configuration file.
