Yocto build for u-boot-imx fails with out of memory (error 137)
tdoering
when building u-boot-imx 2020.04 with the latest dunfell branch using bitbake, the build fails with the error '137'.
The process `u-boot-imx:comp` eats up all RAM (I have 32GB) and finally gets killed by the oom-killer.
Any ideas?
Greetings,
Thomas
Tags (3)
Dhruvit
Hi @tdoering,
I hope you are doing well.
Could you please share more info and the steps followed to build u-boot-imx?
Please mention how you set up yocto for i.MX and error logs.
Thanks & Regards,
Dhruvit Vasavada
pinkman10
Hi @Dhruvit,
I am also facing the same issue. i have attached the build error below. if you want any further info, feel free to ask.
