Yocto bitbake linux-imx -c menuconfig issue
wangtsungli
Hi community,
I'm working on i.MX6 sabre-SD Dual lite and build Yocto image.
I connect to my server to build source code via putty from my windows computer.
While I trying to modify my defconfig, I execute below command.
However, It did not show manual out like below picture.
It will stuck at do_menuconfig(below picture)
If picture is no clear please refer to below attachment.
How can I solve this problem?
marcomadrigal
Try:
bitbake virtual/kernel -c menuconfig
Also, in your picture it looks it is executing correctly, how long did you wait? Depending of your system it should take some time before opening the configuration window.
-Marco
http://www.ridgerun.com
Bio_TICFSL
Hi tsung,
Change the command to:
bitbake -c menuconfig linux-imx
If the problem persist please check:
https://community.nxp.com/thread/376369
