Hello!
There is a problem with $THISDIR resolving in Yocto (1.8 / Fido). I just want to ask if it's a bug or expexted behavior.
I created *.inc file which simply replaces patching mechanism. Instead of making patches for each change I just want to overwrite old files with new, manually edited. Just to make my layer a bit more "developer-friendly" for quick tests.
| patch-sources.inc |
do_unpack_append() { bb.build.exec_func('do_update_sources', d) } do_update_sources() { cp ${THISDIR}/${PN}/update/ ${S} -R } |
Once I add this file to *.bbappend, I expect any sources located in meta-mylayer/.../${PN}/update to be copied on top of extracted sources:
| meta-mylayer/.../u-boot-fslc_2015.04.bbappend |
require ${THISDIR}/../../recipes-common/patch-sources.inc FILESEXTRAPATHS_prepend := "${THISDIR}/${PN}:" |
So...
in bbappend file: ${THISDIR} is resolved to meta-mylayer/... in both cases.
but in included patch-sources.inc: ${THISDIR} is resolved to meta-fsl-arm/...
Is it OK or a bug?
Dmitry
Did _require_ work?
I would expect require to look for a patch-sources.inc inside other layer.
In fact I don't understand your point with this change. I have never saw THIS_DIR being used in installation process.
What do you really want to do?
Just adding to Daiane's comment. I would like to know where is the .inc file located since that may also affect how the THISDIR variable is interpreted. In both cases inside meta-mylayer it seems to be giving the correct directory back.
