Dear Yocto Experts,
I learnt about Yocto Extensible SDK from following discussion : https://community.nxp.com/t5/i-MX-Processors/Yocto-Hardknott-and-iMX8MP-error-generating-extended-sd...
I would like to know what is the difference if any.
Thanks in advance and best regards,
Khang
已解决! 转到解答。
Thank you for your interest in NXP Semiconductor products,
As per Yocto eSDK Manual:
The extensible SDK provides a cross-development toolchain and libraries tailored to the contents of a specific image. You would use the Extensible SDK if you want a toolchain experience supplemented with the powerful set of
devtoolcommands tailored for the Yocto Project environment.The installed extensible SDK consists of several files and directories. Basically, it contains an SDK environment setup script, some configuration files, an internal build system, and the
devtoolfunctionality.
As you can see in Yocto eSDK Manual and Toradex Community, devtool is the main feature of it.
