Yocto Project with Repo Init
ylmzhsn_
Hi NXP,
We are getting repo init error.
Referance Link= ( https://www.nxp.com/docs/en/user-guide/IMX_YOCTO_PROJECT_USERS_GUIDE.pdf )
Step 1 :
$ mkdir ~/bin
$ curl https://storage.googleapis.com/git-repo-downloads/repo > ~/bin/repo
$ chmod a+x ~/bin/repo
$export PATH=~/bin:$PATH
Step 2 :
$ git config --global user.name "Your Name"
$ git config --global user.email "Your Email"
$ git config --list
Step 3:
$ mkdir imx-yocto-bsp
$ cd imx-yocto-bsp
$ repo init -u https://github.com/nxp-imx/imx-manifest -b imx-linux-kirkstone -m imx-5.15.52-2.1.0.xml
Error:
manifests:
/home/user/.repo/manifests.git'
manifests: sleeping 4.0 seconds before retrying
fatal: cannot obtain manifest https://source.codeaurora.org/external/imx/imx-manifest
Bio_TICFSL
Hello
This must a proxy issue or I found out you need to have the right gpg key in the ~/.repoconfig folder
Similar to https://stackoverflow.com/a/63125058
But put the key in right place.
mkdir -p ~/.repoconfig/gnupg/
GNUPGHOME=~/.repoconfig/gnupg/ gpg --keyserver hkp://pool.sks-keyservers.net --recv-keys 692B382C
ylmzhsn_
I did what you said but I'm not sure where to put the key.
Error :
gpg: keyserver receive failed: Server indicated a failure
I need to solve this problem urgently.
Best Regards.
