Yocto Hardknott and iMX8MP: error generating extended sdk
已解决
跳至解决方案
4,017 次查看
pierluigi_p
Senior Contributor I
Dear NXP team,
when running the command
    bitbake fsl-image-qt5 -c populate_sdk_ext
the file /usr/bin/protoc is provided by both protobuf-native and tensorflow-protobuf-native, aborting the build.
Assuming (from the history of the current recipe) that protobuf and tensorflow-protobuf should cohexist, I suppose than protoc could be renamed to tf-protoc in tensorflow-protobuf recipe.
Could you please double check the attached patch and possibly integrate in meta-imx ?
Best Regards
Pier
标签 (1)
标记 (1)
1 解答
3,976 次查看
Zhiming_Liu
I can see the same issue and i will post your patch in next bsp test.
在原帖中查看解决方案
4 回复数
3,981 次查看
pierluigi_p
The problem is reproducible running
    bitbake imx-image-full -c populate_sdk_ext
Can't you ?
Best Regards
Pier
3,977 次查看
Zhiming_Liu
3,952 次查看
pierluigi_p
Thanks!
Best Regards
Pier
3,994 次查看
Zhiming_Liu
I didn't make fsl-image-qt5 in hardkott before,but our support images are imx-image-full、imx-image-multimedia
