Yocto Hardknott and iMX8MP: error generating extended sdk
Search instead for
pierluigi_p
Dear NXP team,
when running the command
    bitbake fsl-image-qt5 -c populate_sdk_ext
the file /usr/bin/protoc is provided by both protobuf-native and tensorflow-protobuf-native, aborting the build.
Assuming (from the history of the current recipe) that protobuf and tensorflow-protobuf should cohexist, I suppose than protoc could be renamed to tf-protoc in tensorflow-protobuf recipe.
Could you please double check the attached patch and possibly integrate in meta-imx ?
Best Regards
Pier
Qmiller
I can see the same issue and i will post your patch in next bsp test.
pierluigi_p
The problem is reproducible running
    bitbake imx-image-full -c populate_sdk_ext
Can't you ?
Best Regards
Pier
Qmiller
pierluigi_p
Thanks!
Best Regards
Pier
Qmiller
I didn't make fsl-image-qt5 in hardkott before,but our support images are imx-image-full、imx-image-multimedia
