Yocto Hardknott and iMX8MP: error generating extended sdk
2,150件の閲覧回数
pierluigi_p
Contributor V
Dear NXP team,
when running the command
    bitbake fsl-image-qt5 -c populate_sdk_ext
the file /usr/bin/protoc is provided by both protobuf-native and tensorflow-protobuf-native, aborting the build.
Assuming (from the history of the current recipe) that protobuf and tensorflow-protobuf should cohexist, I suppose than protoc could be renamed to tf-protoc in tensorflow-protobuf recipe.
Could you please double check the attached patch and possibly integrate in meta-imx ?
Best Regards
Pier
タグ(1)
2,109件の閲覧回数
Zhiming_Liu
I can see the same issue and i will post your patch in next bsp test.
4 返答(返信)
2,114件の閲覧回数
pierluigi_p
Contributor V
The problem is reproducible running
    bitbake imx-image-full -c populate_sdk_ext
Can't you ?
Best Regards
Pier
2,110件の閲覧回数
Zhiming_Liu
2,085件の閲覧回数
pierluigi_p
Contributor V
Thanks!
Best Regards
Pier
2,127件の閲覧回数
Zhiming_Liu
I didn't make fsl-image-qt5 in hardkott before,but our support images are imx-image-full、imx-image-multimedia
