Hi Nxp/Freescale,
When to build latest release Yocto BSP will get failed!
please check your server configuration correct
I can make sure the problem on NXP/Freescale side, due to 3.14.52 passed testing and manual to download previous version package are well!
please check the below package list
http://www.nxp.com/lgfiles/NMG/MAD/YOCTO/imx-lib-5.5.tar.gz
http://www.nxp.com/lgfiles/NMG/MAD/YOCTO/kernel-module-imx-gpu-viv-5.0.11.p8.6.tar.gz
http://www.nxp.com/lgfiles/NMG/MAD/YOCTO/imx-vpuwrap-1.0.68.bin
http://www.nxp.com/lgfiles/NMG/MAD/YOCTO/imx-parser-4.1.4.bin
http://www.nxp.com/lgfiles/NMG/MAD/YOCTO/imx-vpu-5.4.35.bin
http://www.nxp.com/lgfiles/NMG/MAD/YOCTO/imx-gpu-viv-5.0.11.p8.6-hfp.bin
http://www.nxp.com/lgfiles/NMG/MAD/YOCTO/imx-test-5.7.tar.gz
http://www.nxp.com/lgfiles/NMG/MAD/YOCTO/imx-gst1.0-plugin-4.1.4.tar.gz
http://www.nxp.com/lgfiles/NMG/MAD/YOCTO/imx-gpu-sdk-2.3.2.bin
Solved! Go to Solution.
Good day to all,
Issue has been resolved can you please test the download once more please.
Good day to all,
I've started a new clean build of fsl-image-gui to make sure I only get errors caused by currently missing sources and until now (still running) these files cannot be found:
The second file is normally redirected to http://www.nxp.com/lgfiles/NMG/MAD/YOCTO/imx-parser-4.1.4.bin;fsl-eula=true I think.
Hi, jorge_plascencia
Still missed package for fsl-image-qt5:
http://www.nxp.com/lgfiles/NMG/MAD/YOCTO/imx-qtapplications-1.0.9.bin
All files have been tested and are on the server, Deng are you still having issue ?
Yes, still missed something when graphics backend to setting to "x11", just passed on "xwayland" and "wayland" backend
and
http://www.nxp.com/lgfiles/NMG/MAD/YOCTO/xserver-xorg-video-imx-viv-5.0.11.p8.6.tar.gz
but this package can find out on sources.buildroot.net
but I know imx-qtapplications should be a demo programs package,
so will try to ignore it first
have a solutions
Thank for your support!
This seems to be related/duplicate of https://community.nxp.com/message/857418?commentID=857418 for me.
Update, still missed the below list
Hello KunYi Chen,
I was able to reproduce this issue and I will escalate it. In the meantime, the L4.1.15_1.1.0-ga does work correctly.
