HI Team,
Customer asked us to implement GPT capture on i.MX6SX, provided sample code in uboot to customer for reference. FYI.
Purpose:
Some customers want to enable GPT Capture mode on their design. It can be used to measure signal width. Here is sample code in uboot for GPT capture function.
HW Platform:
i.MX6SX SDP board
HW Modification:
SD1_CMD: config it to CLKO1 function
SD1_DATA0: config it to GPT Capture 1 input
We can shorten TP86 to TP89 for quick test:
SW Platform: BSP 3.10.53_GA
SW code path: arch\arm\cpu\armv7\mx6\clock.c
SW detail: Pls refer to attached for detail
Lambert
Original Attachment has been moved to: log_both-edge.txt.zip
Original Attachment has been moved to: clock.c.zip
HI Lambert!
Can provide drive source?
Zhujun zhu
