Hi community.
Our partner has question.
Would you please teach me how to set the data.
For H.264 (YCrCb420) video data is output from the HDMI as a YUV422.
what can be realized as performing any processing.
Solved! Go to Solution.
Takashi-san
We are sorry for the delay. This support request has been assigned to AE team. If you do not se response in 3 days, please contact me again.
Yixnig
You can do YUV420 to YUV422 conversion using IPU.
Saurabh
Thank you for your replay.
I understand the IPU can be converted YcrCb 4:02 to YUV422 possible.
Pleased to advice on how to convert and what register setting with HDMI.
Hi Takashi, you can run the followed command to switch HDMI output between YUV and RGB format:
// Switch to YUV output mode
$ echo 0 > /sys/devices/platform/mxc_hdmi/rgb_out_enable
// Switch to RGB output mode
$ echo 1 > /sys/devices/platform/mxc_hdmi/rgb_out_enable
