I am new here.I want to convert the YUV type file to PNG or JPEG?
Is there anyone know it? Is the IPU can help to convert it ?
Thanks anyway!
Solved! Go to Solution.
The IPU does not provide that functionality. However the codecs included in the Mult Media Framework support the conversion of YUV to JPEG.
Thanks for you information, My solution as below:
capture a frame as yuv format, then use vpu encode the yuv to jpeg image, Is that a really solution?
Yes, it correct, I use GStreamer modiule for this.
Thanks veru much!
