XWayland windowing system in imx8mm BSP L4.14.98_2.0.0 for yocto linux
anushan
Hello Everyone,
I wanted to know if java swing applications are supported on XWayland windowing system provided by default in the BSP Linux-L4.14.98_2.0.0 for imx8 M mini board?
gusarambula
Hello Anusha N,
From what I understand Java Swing can run under XWayland. However, there is not built in support on the BSP Release, you would need to port it for your application.
I hope this helps!
