X11 forwarding on imx8mp-evk with xwayland
2,035件の閲覧回数
axjensen
We are unable to get X11 forwarding on imx8mp-evk with xwayland.
xauth is added to xwayland and sshd set up to allow X11 forwarding
We are trying to execute an application as root.
Doing an ssh connection as root with X11 Forwarinng we launch an application from the terminal.
The GUI of the application  then is displayed on the monitor attached to the imx8mp and not forwarded over SSH.
What might be the problem?
2 返答(返信)
2,003件の閲覧回数
joanxie
1,989件の閲覧回数
axjensen
Thank you @joanxie
As I mention in the original message, xauth is already installed.
I've have also tried the advices from you two last links, which does not solve the problem. So I am stuck.
In your first link, a user @OtavioSalvador has successfully solved the problem by configuring OpenSSH. It would be of great help to know what he had to change from default values.
Thank you,
