Wrong imx6 fstab.freescale patch for SD card usage in Android jb43
mabel
Hello all,
i found a little typo in the user guide docs how to build android jb4.3 for SD card usage. The fstab.freescale patch is not correct, there some missing "-". Here is the right fstab.freescale to build android which can be booted from SD card. I've copied this from the jb43 demo image.
best regards,
Martin
# Android fstab file.
#<src>                                                  <mnt_point>         <type>    <mnt_flags and options>                       <fs_mgr_flags>
# The filesystem that contains the filesystem checker binary (typically /system) cannot
# specify MF_CHECK, and must come before any filesystems that do specify MF_CHECK
#/devices/platform/sdhci-esdhc-imx.2/mmc_host/mmc1 /mnt/extsd vfat defaults voldmanaged=sdcard:auto
/devices/platform/sdhci-esdhc-imx.1/mmc_host/mmc2 /mnt/extsd vfat defaults voldmanaged=sdcard:auto
/devices/platform/fsl-ehci /mnt/udisk vfat defaults voldmanaged=sdcard:auto
#/dev/block/mmcblk0p5    /system      ext4    ro        wait
#/dev/block/mmcblk0p4    /data        ext4    nosuid,nodev,nodiratime,noatime,nomblk_io_submit,noauto_da_alloc,errors=panic    wait,encryptable=footer
#/dev/block/mmcblk0p6    /cache       ext4    nosuid,nodev,nomblk_io_submit                                                    wait
#/dev/block/mmcblk0p7    /device      ext4    ro,nosuid,nodev        wait
#/dev/block/mmcblk0p1    /boot        emmc    defaults        defaults
#/dev/block/mmcblk0p2    /recovery    emmc    defaults        defaults
#/dev/block/mmcblk0p8    /misc        emmc    defaults        defaults
/dev/block/mmcblk1p5    /system      ext4    ro        wait
/dev/block/mmcblk1p4    /data        ext4    nosuid,nodev,nodiratime,noatime,nomblk_io_submit,noauto_da_alloc,errors=panic    wait,encryptable=footer
/dev/block/mmcblk1p6    /cache       ext4    nosuid,nodev,nomblk_io_submit                                                    wait
/dev/block/mmcblk1p7    /device      ext4    ro,nosuid,nodev        wait
/dev/block/mmcblk1p1    /boot        emmc    defaults        defaults
/dev/block/mmcblk1p2    /recovery    emmc    defaults        defaults
/dev/block/mmcblk1p8    /misc        emmc    defaults        defaults
Labels (2)
Tags (3)
