Windows 10 IoT on 8 QuadMax MEK
Jack-Cha
Contributor V
Hi NXP
Looking at the Windows 10 IoT Release Note, 8QM MEK is not found in the supported H/W list.
A customer wants to test Windows 10 on an 8QM with an A72 Core, is it possible to test it?
Thanks.
ADAM
Manuel_Salas
Hello @Jack-Cha ,
Unfortunately, Windows 10 IoT is not supported on 8QM.
Best regards!
Jack-Cha
Contributor V
Hi Aljandro
Thanks for your kind answer.
Can you also please let me know if NXP/MS would support 8QM device with Windows 10 IoT in near futuer?
A customer ask if A72 based 8QM would be able to run Windows 10 IoT via the board level porting.
ADAM
Manuel_Salas
Hello @Jack-Cha
Really I am not pretty sure, the only devices that can work Windows 10 IoT Enterprise are the IMX8M devices, but that OS is not friendly with this embedded chips. So, answering your question, no, we have not a date for any release of Windows IoT  for IMX8QM or if it will exist.
Best regards!
