Windows 10 IoT Enterprise with GPIO Controller
2,430 次查看
hankwang
Hello, I have a GPIO as an output pin that I need to control. I want to know how to control it. Do you have any demo utilities or sample code?
My CPU is 8M Plus.  This pin needs to be controlled. you can refer the attached file.
5 回复数
1,280 次查看
gerfen
@Manuel_Salas  I'm in the same boat WRT to the need to control GPIO.  Can you send me a copy of the GPIO tool please?  Thanks!
2,385 次查看
hankwang
Hello, is there any update?
2,372 次查看
Manuel_Salas
Hello @hankwang
I sent you a direct message. I will re-send to you.
Best regards.
Salas.
2,175 次查看
aber
Hi Alejandro_Salas
I also encountered the same problem, can you send me a copy? thanks!
2,367 次查看
hankwang
Hi @Manuel_Salas  Got it... This tool can switch GPIO levels to high or low. The GPIO tool is good.
