Windows 10 IoT Enterprise with GPIO Controller
2,433件の閲覧回数
hankwang
Contributor V
Hello, I have a GPIO as an output pin that I need to control. I want to know how to control it. Do you have any demo utilities or sample code?
My CPU is 8M Plus.  This pin needs to be controlled. you can refer the attached file.
5 返答(返信)
1,283件の閲覧回数
gerfen
@Manuel_Salas  I'm in the same boat WRT to the need to control GPIO.  Can you send me a copy of the GPIO tool please?  Thanks!
2,388件の閲覧回数
hankwang
Contributor V
Hello, is there any update?
2,375件の閲覧回数
Manuel_Salas
Hello @hankwang
I sent you a direct message. I will re-send to you.
Best regards.
Salas.
2,178件の閲覧回数
aber
Hi Alejandro_Salas
I also encountered the same problem, can you send me a copy? thanks!
2,370件の閲覧回数
hankwang
Contributor V
Hi @Manuel_Salas  Got it... This tool can switch GPIO levels to high or low. The GPIO tool is good.
