Dear JorgeCas,
Thank you for your reply.
- Do you get error logs?
How can I get the error log?
(Obtaining via remote connection of windbg, etc.)
- All USB devices except USB Pen Drive working fine?
Unfortunately, we do not have any USB 3.0 compatible USB devices other than
USB memory sticks.
- Have you tried other USB Pen Drive models/manufacturers? Is there the same problem?
The following USB memory sticks were not recognized:
manufacturer : ELECOM
model : MF-HSU3A16GBK
Would it be possible for your company to carry out a similar check using a reference board?(We think you'll be able to see this phenomenon straight away.)
If the USB 3.0 compatible USB memory is recognized correctly, please tell us the manufacturer and model number of the USB memory.
Best regards.
Koji Okuda
