Last week we tested DDR singal of read mode. The value of tDQSQ-Diff is 235.14ps and that’s more than the high limit 200ps found to fail.
But the communication between the CPU(I.MX6S) and DDR3 is normal now. For CPU, this one even if NG, is no effect on communication, can we think so?
Solved! Go to Solution.
Hi 王 剑翰
value of tDQSQ-Diff is 235.14ps may be just caused
by placement of oscilloscope probe,
since for example for FR4 board trace length may lead to delay
about 7ps/mm.
Also for correct tDQSQ one needs to perform ddr calibration,
check sect.13 "Read DQS Delay Calibration"
AN4467 i.MX 6 Series DDR Calibration.
chip
Hi 王 剑翰
about 7ps/mm.
chip
Hi Igor Padykov,
Thank you for your kindly help.
As we had performed the DDR stress test using the stress tester tool, I think the deviation should be just caused
by placement of oscilloscope probe.
So the communication between the CPU and DDR3 is normal although the tDQSQ value is not "correct". Then, we can ignore the deviation.
Do you agree with my understanding? If I am wrong, please kindly correct me, thank you!
Hi 王 剑翰
yes, if processor works well
you can safely ignore this. Your
understanding is right.
chip
Thank you~!
