We're trying to use Azurewave chip AWNH391(marvell SD8777 ) for Bluetooth functionality on imx6SL EVK via the SDIO interface (SD3 slot on EVK).
Software: Android 4.4.3 with IMX patches
Compiled Marvell Bluetooth driver for imx6
The driver installs correctly (insmod bt8xxx.ko) and downloads firmware onto the chip. Then I use BDT to enable bluetooth and test it. However bluetooth is not getting enabled. From the Android logs it seems like the
libbt-vendor.so is getting loaded (I'm assuming this is for a Broadcom chip?)
Question:
Apart from getting the right drivers for the marvell chipset (which we've already done) what else needs to be done to add bluetooth support?
Original Attachment has been moved to: bdtlog.txt.zip
Original Attachment has been moved to: driverinstallation.txt.zip
Original Attachment has been moved to: Androidlog.txt.zip
I have not found information with the chip you are using. The closest thing is the next document:
142-00207-517_iMX6X_SX-SDCAN_BT.pdf
I hope that hleps
/Alejandro
