Wifi and BT not working in IMX8M mini evk board using Android 11.2.2
Ruban1
I tried to enable in GUI but it falling to enable both WIFI and BT in latest 11.2.2
Kindly provide solution
Thanks and Regard
Ruban
Rita_Wang
I think you are using the old version i.MX8MM EVK board with Qualcomm 1PJ QCA9377.
After the Android 11 version BSP the default support NXP 88W8987 Wi-Fi/BT module.
Rita_Wang
Ruban1
Yes we are using old version imx8mm evk board.
Can we port Android 11.2.2 with old evk and work for Qualcomm.
If you have any related documents kindly provide.
Only for W-Fi and BT
Thanks and regards
Ruban
