Hi Igor,
Thank You for the reply.
The system is suspending now after commenting the gpio0 node in the dtsi...Any idea what is the link between GPIO0 bank and SDIO suspend functionality?
Also when resuming back , I am getting time out in sdhci_reset() with the below prints
[ 579.856720] mmc1: Reset 0x4 never completed.
[ 579.860990] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 579.867429] mmc1: sdhci: Sys addr: 0x00000000 | Version: 0x00000002
[ 579.873875] mmc1: sdhci: Blk size: 0x00000040 | Blk cnt: 0x00000001
[ 579.880322] mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x00000000
[ 579.886767] mmc1: sdhci: Present: 0x01fd8008 | Host ctl: 0x00000001
[ 579.893214] mmc1: sdhci: Power: 0x00000000 | Blk gap: 0x00000080
[ 579.899660] mmc1: sdhci: Wake-up: 0x00000008 | Clock: 0x000020af
[ 579.906106] mmc1: sdhci: Timeout: 0x0000008f | Int stat: 0x00000000
[ 579.912552] mmc1: sdhci: Int enab: 0x007f1003 | Sig enab: 0x007f1003
[ 579.918998] mmc1: sdhci: AC12 err: 0x00000000 | Slot int: 0x00000502
[ 579.925445] mmc1: sdhci: Caps: 0x07eb0000 | Caps_1: 0x8000b407
[ 579.931891] mmc1: sdhci: Cmd: 0x0000371a | Max curr: 0x00ffffff
[ 579.938337] mmc1: sdhci: Resp[0]: 0x00002000 | Resp[1]: 0x00000000
[ 579.944783] mmc1: sdhci: Resp[2]: 0x00000000 | Resp[3]: 0x00000000
[ 579.951228] mmc1: sdhci: Host ctl2: 0x00000000
[ 579.955677] mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000000
[ 579.962121] mmc1: sdhci: ============================================
[ 590.153104] mmc1: Timeout waiting for hardware cmd interrupt.
[ 590.158868] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 590.165316] mmc1: sdhci: Sys addr: 0x00000000 | Version: 0x00000002
[ 590.171761] mmc1: sdhci: Blk size: 0x00000040 | Blk cnt: 0x00000001
[ 590.178206] mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x00000000
[ 590.184653] mmc1: sdhci: Present: 0x01fd8009 | Host ctl: 0x00000001
[ 590.191098] mmc1: sdhci: Power: 0x00000000 | Blk gap: 0x00000080
[ 590.197544] mmc1: sdhci: Wake-up: 0x00000008 | Clock: 0x000020af
[ 590.203991] mmc1: sdhci: Timeout: 0x0000008f | Int stat: 0x00000000
[ 590.210437] mmc1: sdhci: Int enab: 0x007f1003 | Sig enab: 0x007f1003
[ 590.216883] mmc1: sdhci: AC12 err: 0x00000000 | Slot int: 0x00000502
[ 590.223330] mmc1: sdhci: Caps: 0x07eb0000 | Caps_1: 0x8000b407
[ 590.229775] mmc1: sdhci: Cmd: 0x0000371a | Max curr: 0x00ffffff
[ 590.236221] mmc1: sdhci: Resp[0]: 0x00002000 | Resp[1]: 0x00000000
[ 590.242667] mmc1: sdhci: Resp[2]: 0x00000000 | Resp[3]: 0x00000000
[ 590.249112] mmc1: sdhci: Host ctl2: 0x00000000
[ 590.253562] mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000000
[ 590.260006] mmc1: sdhci: ============================================
[ 590.767140] mmc1: Reset 0x2 never completed.
This prints occur continuously for a pretty long time and then
mmc1: error -110 during resume (card was removed?)
print appears and the Wi-Fi driver shows IOCTL failed prints.
I tried to increase the timeout check window for sdhci reset and clock but the issue persists.
Any help would be appreciated.
