Why separate vfat partition for boot?
1,103 次查看
diarmuidcollins
The standard sabresd image has a separate boot partition which is formatted as a vfat filesystem
Why is this? Why vfat?
I've read that the reason for separate boot partitions was that older BIOS's could only read small partitions. However why format it as vfat?
Is there any reason not to use a single ext4 partition for the rootfs and boot?
0 回复数
