Why nop is inserted in imx7d_low_power_idle.S?
Search instead for
satoshishimoda
Senior Contributor I
Hi community,
Our customer have a question about i.MX7S low power mode.
Please see line 698 of arch/arm/mach-imx/imx7d_low_power_idle.S in L4.1.15_1.0.0-ga.
There are 25 nops after wfi from this line.
Would you let me know the intent why there are these nops?
Satoshi Shimoda
Labels (3)
Yuri
  when exit low power mode, some delay is necessary to make sure signals
stable enough for DDR operation.
Yuri
Note: If this post answers your question, please click the Correct
Answer button. Thank you!
Yuri
Yuri
satoshishimoda
Hi Yuri,
Thank you for your reply.
What is the factor to decide how long delay is needed?
Time to stabilize DDR clock from PLL?
Or DDR chip requires some delay?
Satoshi Shimoda
Yuri
 when exit  low power mode, ~10us delay is necessary.
Yuri.
