Hi @surfskidude
Thanks a lot for reaching our technical support.
Regarding your issue, when the MCU is trapped in the 0xdeadbeef address, it is usually due to some incorrect configuration of the peripheral used and actually if you pause the debugger, you might see a HardFault sometimes or simply the debugger is lost due an incorrect flow of the program. So my question is, did you modified something on the SDK example? and also, do you have the Ethernet port connected for that example?
Hope we can hit the nail on the head soon, please let me know if you have more questions or comments.
Best Regards.
Pablo Avalos.
