Why can't I read the correct value after programming the fuse?
603 次查看
ZongYue
After I use fuse prog <bank> <word> <value> to write the SRK_HASH value, I want to use fuse read <bank> <word> to read the data for comparison, but the value returned is 0.
But when the power is turned on again, the correct data can be read.
After writing SRK_HASH, how long do I need to wait for the fuse to complete the prog program?
ZongYue
588 次查看
Harvey021
The fuse values can be effective after SoC reset. Normally.
For comparison, you can use the command line "fuse sense <bank> <word>" after writing and without reset.
Harvey
589 次查看
Harvey021
Harvey
