Who use the LTIB compiled UBIFS file system?
1,228 次查看
embed_wu
Hello, everyone
          Now I use the LTIB compiler UBIFS, a series of configuration, compiled by rootfs.ubifs.img, but finally burning written into the NANDFLASH ( using NANDFLASH is MT29F4G08AAA ), reported the following error:
VFS: Cannot open root device" ubi0: rootfs0" or unknown-block ( 0, 0)
Please append a correct" root =" boot option; here are the available partitions:
          I was through the SD card login system, use the command flasheraseall / dev / MTD1 and nandwrite / dev / MTD1 rootfs.ubifs.img. Is my LTIB configuration information wrong? I am in the kernel configuration are hooked on the UBI file system support, in the Target Image Generation - > Options:
Choose your root filesystem image type
Target image: ( UBIFS ) - - - >
[ ] Run a command after building the target image
        ( 128KiB ) UBIFS physical erase block ( PEB ) size
        ( 126976 ) UBIFS logical erase block ( LEB ) size in Bytes
        ( 2048 ) UBIFS maximum logical erase block ( LEB ) count
        ( 2048) UBIFS minimum I / O unit size
              UBIFS compression type ( not support favor LZO ) ( UBIFS LZO compression ) -- >
       Who can help me?
标记 (1)
684 次查看
fluiss
Hi GNSS,
  Did you solve the problem?.. I have the same as you and I can't find how to fix it.
Thank you
Fernando
684 次查看
mdc
Contributor V
I'd recommend generating your ubifs image manually outside of LTIB. See below link for some tips. Is for an MX53, but concepts are the same for other devices.
http://imxcommunity.org/group/imx53hardwaredesign/forum/topics/flashing-nand-with-ubifs-and-burning-...
684 次查看
embed_wu
No one can help me?
