Which gstreamer plugin for iMX(8) is better ?
已解决
跳至解决方案
2,908 次查看
khang_letruong
Senior Contributor III
Dear All,
I'm a little confused of which gstreamer-imx plugin that is most suitable for iMX8MM/iMX8MP board that I have. Concretely :
From Freescale repository, there's recent v2 branch that supports iMX8M, iMX8MM platforms : https://github.com/Freescale/gstreamer-imx
From NXP's Code Aurora repositories :
https://source.codeaurora.org/external/imx/imx-gst1.0-plugin/
https://source.codeaurora.org/external/imx/gst1.0-plugins-fsl/
Both have "i.MX Gstreamer 1.0 Plugin" in description.
I would like then which one is better to be used with the following documentation :
https://community.nxp.com/t5/i-MX-Processors-Knowledge-Base/i-MX-8-GStreamer-User-Guide/ta-p/1098942
Thanks in advance and best regards,
Khang
标记 (1)
1 解答
2,894 次查看
Bio_TICFSL
Hello  Khang,
The Gstreamer in the official is gstreamer 1.0 and comes from:
You can find the documentation in the release notes and linux reference manual on your yocto BSP documents, for usage you can use the community.
在原帖中查看解决方案
1 回复
2,895 次查看
Bio_TICFSL
Hello  Khang,
