Where it will be generated building images for to boot from sdcard
925 次查看
venu_gopal
After i was given bitbake meta-toolchain where it will be generated below images for boot from sdcard.
To boot a Linux image on i.MX 6 and i.MX 7, the following elements are needed:
• Bootloader (U-Boot)
• Linux kernel image (zImage)
• A device tree file (.dtb) for the board being used
• A root file system (rootfs) for the particular Linux image
• Arm Cortex-M4 Image for iMX 7ULP
880 次查看
karangajjar
Senior Contributor II
Hi Venu Gopal,
You can check for images in:
<build_dir>/tmp/deploy/images/<board>/
Karan Gajjar
