Hi, i build the iMX6q linux(L3.0.35_1.1.0_121218_source.tar.gz & gst-launch) in ubuntu 10.04.
but, error as shown below.
Try fsl-alsa-plugins-1.0.25.tar.gz.md5 from the GPP
http://bitshrine.org/gpp/fsl-alsa-plugins-1.0.25.tar.gz.md5:
14:57:40 ERROR 404: Not Found.
Try fsl-alsa-plugins-1.0.25.tar.gz from the GPP
http://bitshrine.org/gpp/fsl-alsa-plugins-1.0.25.tar.gz:
Can't get: fsl-alsa-plugins-1.0.25.tar.gz at ./ltib line 802.
Try gst-plugins-gl-0.10.3.1.tar.gz.md5 from the GPP
http://bitshrine.org/gpp/gst-plugins-gl-0.10.3.1.tar.gz.md5:
15:35:00 ERROR 404: Not Found.
Try gst-plugins-gl-0.10.3.1.tar.gz from the GPP
http://bitshrine.org/gpp/gst-plugins-gl-0.10.3.1.tar.gz:
Can't get: gst-plugins-gl-0.10.3.1.tar.gz at ./ltib line 802.
This file is not in the http://bitshrine.org/gpp/
Where can I find this files?
Solved! Go to Solution.
Hello,DongHyun,
Maybe you didn't patch codec . See attachment. try to add them to /opt/freescale/pkgs
Weidong
