Hi - I've searched but cannot locate the Yocto BSP for my MCIMX8M-EVK. I've noticed several questions on the Forum referencing a Yocto build for this kit.
Can somebody please point me to the repositories and quick start guide?
Thank you very much.
Phil
Solved! Go to Solution.
Hello Phil,
There is a beta BSP release. You can find the documentation with the repository and the quick start guide on the link below (you may need to login to download this documentation bundle).
https://www.nxp.com/webapp/Download?colCode=L4.9.51_8MQ_BETA_LINUX_DOCS
I hope this helps,
Hello Phil,
I hope this helps,
Hi gusarambula,
I found it. Thank you for the support.
Phil
