Hi everybody,
I get LTIB installer from this link:
LTIB : Downloadhttp://ltib.org/
When I launch it, I can't select i.MX25 platform because It doesn't exist. So, this LTIB seems not support i.MX25. Is there any other LTIB available (with i.mx25 support)?
Kind regards
Solved! Go to Solution.
Below are some links how to use Ubuntu 12.04 (11.10) :
https://community.freescale.com/servlet/JiveServlet/download/323503-258661/ubuntu_11_10_host.zip
Thank you yuri. Could you tell me if this LTIB installer is compatible with Ubuntu 12.04LTS?
thanks Yuri, this topic could be closed, I've got the solution. regards
