Where can i get the latest BSP of i.MX6ULL Evaluation Kit , Except for yocto method
510015320
Because google's link is not avaliable in china ,so yocto project can not use by setting.I need to build uboot and kernel in standalone environment,but i can not  generate it from yocto project. where can i get the latest  BSP of i.MX6ULL Evaluation Kit? Please tell me the github link.
Downloading Repo source from https://gerrit.googlesource.com/git-repo
fatal: Cannot get https://gerrit.googlesource.com/git-repo/clone.bundle
fatal: error [Errno 110] Connection timed out
fatal: cloning the git-repo repository failed, will remove '.repo/repo'
turker
You can access kernel and bootloader sources from below links:
linux-imx - i.MX Linux kernel
uboot-imx - i.MX U-Boot
gusarambula
Hello HU YUAN,
Please use the repositories suggested by Tahsin Türker Mutlugün.
Additionally, the following document may help on workarounds when working with the Linux BSP.
Compiling L5.4.3_1.0.0 BSP On Ubuntu 180.4 LTS
https://community.nxp.com/docs/DOC-346009
I hope this helps!
