I am looking for a source from which to purchase an FPC cable that can be inserted into the i.MX 8M EVK Extension connector. I am evaluating the i.MX 8M for audio processing and would like to connect my audio board to the i.MX 8M EVK.
Hello David Fitting,
There is not a part number for this cable but you may use a standard flexible flat cable with the necessary number of pins to connect your audio board to the connector.
