I am using the IMX7 Dual Sabre board. (https://www.nxp.com/support/developer-resources/evaluation-and-development-boards/sabre-development-...)
I need to do hardware debugging now.
I understand that this board has a JTAG-Connector on J12.
I'm trying to connect to this board with Trace32, which seems to require an adapter.
Please ask the person who knows where to buy the adapter.
if you use Trace 32, you can find adapter from the link as below:
seems like the board have a smaller JTAG connector than usual.
You can find a Probe here https://www.segger.com/products/debug-probes/j-link/, but you have to buy an additional adapter, so the probe can fit onto your board. (Adapter https://www.segger.com/products/debug-probes/j-link/accessories/adapters/overview/)
Basically you can use whatever probe you want.
