Hi all:
Is there anyone can explain the relationship or association between CSI Bridge and CSI Host Controller in imx8mq?
Does CSI bridge be linked after CSI host controller? And the data from camera module is transmitted from MIPI D-phy, CSI Host Controller then to CSI bridge. is it correct?
R,
Hi Tsai
I believe you are right, data from camera module is transmitted from
Hi igorpadykov:
Thanks for your quick reply.
Is there a document showing the association between the MIPI CSI and CSI Bridge?
Referring to the forum Explenation for HS-SETTLE parameter in MIPI CSI D-PHY registers , do you know how to calculate the HS-Settle value on imx8mq? is it based on the the clock IMX8MQ_CLK_CSI1_ESC we set in the fsl-imx8mq.dtsi
R,
Ben
Hi igorpadykov:
I have already finished my task. Thanks for your prior information. And then the HS-Settle value is set base on the clock IMX8MQ_CLK_CSI1_ESC.
R,
Ben
